Egreak525
Mar 01, 2019Aspirant
RBK53 Orbi satellites...no devices show connected
I have the CBR40 modem/router combo set up in the family room where the outside cable comes into the house which is on one end of the house. I have one satellite that I had set up approximately 25-3...
Mar 02, 2019Guru - Experienced User
What FW is currently loaded?
Does a browser and web page for the CBR show devices connected?
Orbi What is the size of your home? Sq Ft? 30 feet is recommended in between CBR40 and satellite to begin with depending upon building materials.
What WPA security modes are you using?
Try enableding Beamforming and MIMO.
Please post about this here:
https://community.netgear.com/t5/Orbi-with-Built-in-Cable-Modem/bd-p/en-home-orbi-cable
Egreak525 wrote:
I have the CBR40 modem/router combo set up in the family room where the outside cable comes into the house which is on one end of the house. I have one satellite that I had set up approximately 25-30ft away in another room that is primarily central to the house. It had no problem connecting to the router but the devices connecting to it showed a weak signal on the app compared to those connecting to the router wirelessly. One of the devices was just outside of the room, probably 10-15ft away, and the others were directly below the satellite in the basement. I've done a speed test while my phone has been connected to the internet and the speeds seem to be good, 65-95mbps, with 100mbps paid speed. I tried moving the satellite further away to reduce overlap but no difference at all. Any suggestions? I wish there was a way to visually map the wifi
- Egreak525Mar 03, 2019AspirantThanks!
I just recently updated the satellite FW after this post to the newest hoping it would help.
My house is 3200sqft. Two story with a partially finished basement. I have the router in the family room near the side of one house and the satellite is in an office which does require it to get a signal through 2 walls which I wouldn't see being a problem given the purpose of a satellite.
I already had beaming enabled but enabled MIMO and seems that most devices are connecting to router even though closer to satellite. I tried fast roaming but some devices were switching back and forth which caused a bad connection when connecting to satellite so I turned off.
A dedicated channel for the router seems to give a better signal to devices but didn't help from satellite.
My next move will be to move the satellite to new location with less interference from walls or moving to basement to get a wired connection. Will post updates.- FURRYe38Mar 04, 2019Guru - Experienced User
What is the distance between the base router and satellite?
if you temporarily turn OFF the base router, do your devices connect to the satellite? Then turn back on the base router.
Egreak525 wrote:
Thanks!
