ShrumIowa
Dec 17, 2019Aspirant
RBK53 Orbi system or keep my RAX120 and add EAX80?
My RAX120 is not cutting it alone in my house. I am liking what I have heard about mesh systems. Would adding the EAX80 be true mesh system, or am I better off just going with the Orbi RBK53? What I w...
Dec 17, 2019Guru - Experienced User
The EAX would work similarly to the Orbi system's satellites.
What is the size of your home? Sq Ft? 30 feet is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-router
Would be similar for your RAX system.
House size vs Orbi systems:
https://www.netgear.com/orbi/default.aspx
https://www.netgear.com/orbi/wifi-systems.aspx
https://kb.netgear.com/000038220/What-are-the-hardware-specifications-of-the-available-Orbi-WiFi-Systems
- ShrumIowaDec 17, 2019AspirantThank you for your help! My house is roughly 4000 sq ft. 3 floors including my basement. So the EAX acts like a mesh system? I guess I’m not sure how it turns to a mesh system. I know with the Orbi system I can get outdoor coverage too that will help out by my pool.
- FURRYe38Dec 17, 2019Guru - Experienced User
Well most MESH systems are based on having 3 wifi radios, 1 2.4 and 5Ghz and 1 5Ghz wireless backhaul for the main wifi connection between satellites or EX's that supports this. Orbi already has this built in. The 3rd 5Ghz radio is not user configurable or able to connect to with any wifi devices accept for the satellites.
Heres a wifi comparison between the RAX120 and EAX80:
RAX120:
WiFi 6 (802.11ax) Dual Band WiFi (AX6000)
- 2.4GHz AX: 4x4 (Tx/Rx) 1024-QAM
20/40MHz, up to 1.2Gbps
- 5GHz AX: 8x8 (Tx/Rx) 1024-QAM
20/40/80/160MHz, up to 4.8GbpsEAX80:
— 2.4GHz AX: 4x4 (Tx/Rx) 1024-QAM
— 5GHz AX: 4x4 (Tx/Rx) 1024-QAM
160MHz, up to 4.8GbpsEAX only handles 4.4 MIMO streams on 5Ghz vs the RAX has 8x8 MIMO streams. Mostly handling of bandwidith and device connections here. The connection rates are the same this is good.
By the looks these only have 2 radios. So mostly the EAX would be a extender rather then a MESH system.
- ShrumIowaDec 17, 2019AspirantThank you , I completely understand now. I have never been a fan of extenders. I couldn’t find anything about a third radio for the EAX and RAX. Basically they threw the “mesh” in but it’s not a true mesh system. Only the Orbi system has them.
