aurelienphoto
May 14, 2020Tutor
RBK53 ou RBK23 + RBS50 Y
Hello, Having a budget of about 550 euros, I am looking for the best solution to increase the WiFi coverage of an associative place composed of two houses and a large courtyard. several people connect simultaneously in the courtyard and in the Houses. I only have one orange box (subscription without medium speed fiber).
it is possible to connect the two houses with a cat8 ethernet cable (70 meters apart).
At identical budget: it seems possible to buy either a KIT RBK 53 alone, EITHER a kit RBK23 + an RBS50Y (if 20 and 50 compatible ??)
so I wonder what would be the best solution between:
- the 3 RBK 50 modules and:
-The 3 RKB20 modules +1 outdoor module (RBS50Y). knowing that I cannot afford a KIT RBK53 + an RBS50Y.
I also heard a lot of recent criticism about the orbi system which would crash a lot more since some updates. do you know what it is?
thank you very much for your precious advice.
Aurelian
1 Reply
Sort By
30 feet is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-router
I would LAN cable connect the two houses if possible. LAN cable can be burried.
You can try this as well between houses:
