thisguy
Jun 21, 2018Tutor
RBK53 QoS page is missing buttons/options, etc.
I set up my new Orbi RBK53 last night. I went to set up QoS and there's nothing on the page but a speed test. I found this thread being marked as "solved", https://community.netgear.com/t5/Orbi/QOS-i...
Jun 21, 2018Guru - Experienced User
Orbi and some other non Orbi NG routers have this simple QoS where speedtest is done and from there sets up QOS automatically.
There is no advanced QoS features like some other routers.
If you need more advanced QoS featuers then you may need to find something else.
- thisguyJun 21, 2018TutorI don't need any special qos features. However, I do expect there to be something to indicate confidence to the user that qos is active, whether it's a checkbox or a radio button or something like that.
