GAP1
Nov 11, 2019Aspirant
RBK53 QOS SETUP
Ok, I have symetrical 100/100 internet service. The most I can get out of my Orbi is 100 D and 10 UP. I wanted to make sure the QOS was not restricting it. V2.5.0.38
Nov 11, 2019Guru - Experienced User
Are you wired to the back of the RBR when speed testing?
Has a factory reset and setup from scratch been performed since last update? Try this and setup from scratch and be sure to not enable the QoS speed test after completing the setup wizard. Also don't enable any Circle, Amor or Traffic Meter features. Run a speed test with your wired PC and Ooklas installable speed test app.
