GAP1
Nov 11, 2019Aspirant
RBK53 QOS SETUP
Ok, I have symetrical 100/100 internet service. The most I can get out of my Orbi is 100 D and 10 UP. I wanted to make sure the QOS was not restricting it. V2.5.0.38
wchp
Nov 11, 2019Luminary
I have 1000/40 from Comcast and reliably get 41-42 Mbps upstream via wireless. I am also using a CM1100 Cable modem that supports those speeds. The router should not be limiting your bandwidth. I would concur and make sure you are testing with wired connection. Also you do not list what version of firmware you are running on the router. ?
GAP1 wrote:Ok, I have symetrical 100/100 internet service. The most I can get out of my Orbi is 100 D and 10 UP. I wanted to make sure the QOS was not restricting it.
V2.5.0.38
- FURRYe38Nov 11, 2019Guru - Experienced User
And your getting 900Mbps down on the WAN to LAN side?
I wish mine and others would.
He listed the FW version. Same version Im using.
wchp wrote:I have 1000/40 from Comcast and reliably get 41-42 Mbps upstream via wireless. I am also using a CM1100 Cable modem that supports those speeds. The router should not be limiting your bandwidth. I would concur and make sure you are testing with wired connection. Also you do not list what version of firmware you are running on the router. ?
