TomK1951
Aug 15, 2021Aspirant
RBK53 Reconnect Issue with Spectrum new modem
I have used my Orbi RBK53 system (Firmware v2.3.5.30) with my Netgear DOCSIS 3.0 CM600 on Spectrum with no real issue for years. If I lost internet, the modem and Orbi router would reconnect just fi...
Mikey94025
Aug 15, 2021Hero
TomK1951 wrote:Or, is there a way to make the Orbi system reboot automatically when a loss of internet connection is encountered? That may be a quick solution while I research purchasing another Netgear modem.
In my expreience normally the Orbi will automaticallu reaquire its IP address when the modem resets. It's unfortunate that for some reason this is not hte case for your current Spectrum modem. I think there is a good chance that if you get another modem, your Orbi will automatically reacquire its IP address after a reboot. Why don't you purchase one from a local retailer with a good return policy and try it out?
This is probably not an economical solution for you, but useful info for community members. This product is pricey but can be programmed (via website) to power cycle outlets when a network command fails (e.g., ping): https://www.digital-loggers.com/pro.html. I have an older version of it that I used to reset my Comcast modem + Orbi router remotely and when the internet goes down. This product predates today's "wifi power strips" which can offer remote control at a substantially lower price point, so has a much narrower appeal.
