Thalador
Aug 15, 2019Apprentice
RBK53 Setup and Issues
Hey all - I posted this yesterday but it seems to have been removed. Hopefully this sticks and I can get some help I bought the RBK53 3 pack at Costco based on reviews and a lot of research. My h...
Thalador
Thank you for the suggestions. I have an Arris BGW210 with AT&T which does not offer a true bridge mode. I have followed AT&T Forum Post and followed the directions stated to put it in IP passthrough mode. Is there something else to try with this? Is there a special setting on the Orbi I need to do to put it into router mode?
Aug 15, 2019Guru - Experienced User
IP Pass-thru mode should work for the Orbi if you run it in router mode. Nothing else would be needed here. Orbi runs in router mode as it's default mode.
Seen various users with some issues with this model modem. Some have resorted to using the modem in router mode and configuring the Orbi RBR for AP mode...
