cbc50-
Aug 28, 2019Follower
RBK53 since last firmware update ...
Since updating the firmware last week for our ORBI I cannot get live streaming on my iphone of our nest cameras. I get the connection... just no live feed. Any ideas??
Aug 28, 2019Guru - Experienced User
Has a factory reset and setup from scratch been performed?
What prior version of FW did you upgrade from?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
