Billy1956
Jan 01, 2021Aspirant
RBK53 Software Update
My Iphone and Ipad keep wanting me to update to 2.7.0.70. The web interface says that no updates availabe.. Support says 2.7.1.60 for Router and 2.7.0.70 for Sattelites. I am currently on 2.5.2.4. I'...
Feb 02, 2021Guru - Experienced User
v40 is next version after v4 that you have loaded.
Any v2.7.x versions that you see are for US region users only.
v102 of the v2.7 line is most current and is avaialble for those in the US region who wish to update. Users can manually update directly to it:
Using these proceedures:
https://kb.netgear.com/31573/How-do-I-manually-upgrade-firmware-on-my-Orbi-router-using-orbilogin-com
https://kb.netgear.com/000037217/How-do-I-check-and-manually-upgrade-the-firmware-on-my-Orbi-satellite
Update the RBS first then RBR lastly.
Good Luck.
Billy1956 wrote:My Iphone and Ipad keep wanting me to update to 2.7.0.70. The web interface says that no updates availabe.. Support says 2.7.1.60 for Router and 2.7.0.70 for Sattelites. I am currently on 2.5.2.4. I'm confused. I want to make sure I have the security fixes but I do not use Armor or Parental Controls.
