Billy1956
Jan 01, 2021Aspirant
RBK53 Software Update
My Iphone and Ipad keep wanting me to update to 2.7.0.70. The web interface says that no updates availabe.. Support says 2.7.1.60 for Router and 2.7.0.70 for Sattelites. I am currently on 2.5.2.4. I'...
vajim
Feb 02, 2021Master
Billy1956 wrote:My Iphone and Ipad keep wanting me to update to 2.7.0.70. The web interface says that no updates availabe.. Support says 2.7.1.60 for Router and 2.7.0.70 for Sattelites. I am currently on 2.5.2.4. I'm confused. I want to make sure I have the security fixes but I do not use Armor or Parental Controls.
Forget the app
if you must update go with the pc login but stand by for possible headaches
if your network is working with no problems then the question becomes why update? Keep in mind netgear pushes security updates when you need them
vajim
Feb 02, 2021Master
Forget the app
