Southpaw32
May 12, 2020Guide
RBK53 system keeps "rebooting" and WiFi calling is horrible
I recently picked up a refurb RBK53 system from Woot. I've installed, updated the firmware, and did a full factory reset of the router and satalites. Despite all of this a few times a day every devic...
- May 14, 2020
Seems like the RBR isn't stable with two RBS online.
I would make contact with NG support about this. The system should not crash with 2 RBS online. I'd ask about an RMA if needed.
May 14, 2020Guru - Experienced User
Southpaw32
May 16, 2020Guide
Some additional follow-up. My Voip system for work has been giving me fits, so I decided to try AP mode to see if it would fix it.
AP mode magically made all of my VOIP issues disappear.
I was also hoping it would resolve the reboot issue, but it hasn't.
I have an RMA in progress, so I'm anxiously awaiting my replacement system.
Thanks again to FURRYe38 and everyone else for the help!
- FURRYe38May 17, 2020Guru - Experienced User
Hoping the RMA will help keep from crashing. Seems like a HW issue. Hopefully the new RMA unit will work for you in router mode however your still having to deal with the ISP router side as well. AP mode maybe the best way for you to use the Orbi with that modem/router.
Keep us posted.
