Rickvanvenrooij
Oct 04, 2019Aspirant
rbk53 system losing ONLY wifi connection
hello guys, I got a problem with my orbi system going on for a while now. my system sometimes looses wireless connection. So for example every 10 or 20 min the wifi connection goes away for 1 or...
Oct 04, 2019Guru - Experienced User
1. What firmware you running?
2. How far apart are the router and satellites from each other? 30 ft is the minimum distance they should be.
3. How big of an area are they covering? (square ft of your house)
4. Is there much for wireless interference in your area?
5. Is the backhaul going down as well? (hardwire into a satellite to test this)
Some options you can try:
enable/disable beamforming
enable/disable mu-mimo
enable/disable fast roaming
Rickvanvenrooij
Oct 05, 2019Aspirant
Just don't understand it. Everything shows that it's having a perfect connection. The satalites are perfect in range nothing is blocking them.
Everything is running the latest firmware.
And only the router is loosing it's signal. The satallites are always giving a wifi signal
My modem is from ziggo (very highend one)
- Retired_MemberOct 05, 2019
My modem is from ziggo (very highend one)...and IF that modem is dual (modem/router) you CAN'T just plug it in without doing some configuring.
- RickvanvenrooijOct 05, 2019AspirantThe modum is indeed a dual one. But it's in bridgemode so you can connect a router.
What configuring is needed to get it working properly?- ekhalilOct 05, 2019Master- Devices that loose wifi connection, were these attached on 2.4 or 5 GHz band when the issue happens?
- What radio channels are set for 2.4 and 5 GHz bands in Orbi. Please make also a wifi scan and check if those channels are being used by the neighbors.
