comainusa
Jan 31, 2021Tutor
RBK53 v1 with firmware 2.7.2.102?
Hi there, Does anyone know if the latest RBK53 firmware version 2.7.2.102 works with the RBK53 version 1 system (USB connector on back)? Netgear Orbi app only suggests 2.6.1.40 as available updat...
Jan 31, 2021Guru - Experienced User
Can be manually downloaded and manually installed which is preferred:
Update the RBS first before the RBR.
comainusa wrote:Hi there,
Does anyone know if the latest RBK53 firmware version 2.7.2.102 works with the RBK53 version 1 system (USB connector on back)? Netgear Orbi app only suggests 2.6.1.40 as available update.
Thx much in advance.
