jkimbro
May 22, 2020Tutor
RBK53 w/ wired satellite?
Hey all,,, about to jump in to an Orbi mesh system but need to make sure it'll be a fit for my setup. I want to cover two buildings,, (my barn and the house). The barn is out of wifi range of the h...
CrimpOn
May 22, 2020Guru - Experienced User
As long as the ethernet cable supports gigabit, it should work fine. Under 328 ft including the patch cables. Cat5e or better cable.
