blamman
May 24, 2021Apprentice
RBK53 will not reset
My router and satellites are having intermittent issues. Some devices will not attach to the router or connect then after a few minutes disconnect. In the past I have been able to hard reset and ...
May 24, 2021Guru - Experienced User
Is the RBR and RBS all using same version of FW?
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
Even disconnecting the RBR from the ISP Modem and then pressing the reset button for 15 seconds then release and use a wired PC to connect to the RBR, do you get the setup wizard to start?
Be sure to clear out all browser caches before going to the RBRs web page.
blamman
May 25, 2021Apprentice
Hi,
Thank you for the help.
The router and satellites are running V2.7.2.104. I have removed the ethernet backhual and it has gotten better. I believe I may still be getting some wifi drops.
I am connected to xfinity with a sb6141.
Phones and tablets seem to be worse with drops than firesticks.
I have tried numerous times to reset and get the wizard to start but it will not. Sorry for late reply as I have not been home much today
- FURRYe38May 25, 2021Guru - Experienced User
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.Even disconnecting the RBR from the ISP Modem and then pressing the reset button for 15 seconds then release or try selecting the ERASE button on the RBRs web page under Advanced Tab/Administration/Backup and use a wired PC to connect to the RBR, do you get the setup wizard to start?
Try a different browser, IE11, Edge, Firefox or Opera...
Be sure to clear out all browser caches before going to the RBRs web page.- blammanMay 26, 2021Apprentice
My house is around 3500 square feet but all orbi's are downstairs so that is 2000 or so square feet.
Yes each orbi is over 20 feet from the router. IT has been like this for 2 years.
I have tried hard reset for 15 seconds numerous times and reset in the gui but nothing changes.
My routers ip is not default and that never changes.
Thanks
- FURRYe38May 26, 2021Guru - Experienced User
