mroboconnor
Jul 27, 2021Aspirant
RBK53 won't connect to internet (worked for the last year)
I have an RBK53 wired to a vodafone router. vodafone WIFI works fine for the last year, the ORBI WIFIalso worked fine. yesterday it stopped connecting to the internet. symtoms : no internet con...
- Aug 04, 2021
Without changing anything, this situation resolved itself the next day and has been fine ever since.. I believe the ISP must have changed something...
Thanks FURRYe38 for the suggestions..
Unfortunately nothing to learn here :/
Jul 27, 2021Guru - Experienced User
What is the model# of the Internet Service Providers modem/ONT the NG router is connected too? Built in router here? If so, Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
- mroboconnorAug 04, 2021Aspirant
- FURRYe38Aug 04, 2021Guru - Experienced User
Was wondering about the ISP. Glad something was fixed.
Enjoy.
