gobananasnet
Jul 21, 2020Apprentice
RBK53S - how to manually select which router/satellite to connect a specific device to.
RBK53S - I would like to know how to manually select which router/satellite to connect a specific device to. How does one do this, or is it a missing needed feature? For me it is a necessary feature....
Mstrbig
Jul 31, 2020Master
gobananasnet wrote:RBK53S - I would like to know how to manually select which router/satellite to connect a specific device to. How does one do this, or is it a missing needed feature? For me it is a necessary feature.
I have numerous devices, including security system and cameras, as well as so many other devices. Some seem to connect to a device farther away resulting in a weaker signal, especially security cameras do that. If I could manually select which router/satellite it would connect to this would be resolved. Turning off for a half an hour or so and rebooting the cameras, etc. does not fix the issue for some crazy reason. I really need this manualy configuration feature.
Thank you
I agree that feature would be good for stationary devices such as TVs, PCs, Printers, Stereos, etc.. It would insure they would always connect to the proper node.
I just went through the same scenario with several devices. My solution was to shut down and restart the PCs and other devices in question, then go to WIFI settings, forget the network and reconnect. I rebooted the cameras that were having the same issue and they connected to the proper node. One TV kept defaulting to 2.4Ghz, when it fully supported Ghz. I soft rebooted the TV and it connected to 5G.
gobananasnet
Aug 16, 2020Apprentice
Thanks. Unfortunately for us that approach did not work. They still keep connecting to the wrong sattelite / node. Ugh!
