Gussom2c
Feb 11, 2021Aspirant
Rbk53s-100nas
Hi need help orbi will not update P
CrimpOn
Feb 11, 2021Guru - Experienced User
More details would be helpful, such as
- What is the current firmware release?
This can be found in several places, such as
* in the upper right hand corner of the Orbi web interface home page - How are you attempting to update firmware?
(Orbi "app" or the Orbi web interface, Advanced Tab, Administration, Firmware Update?) - Is there a specific reason for the update?
(Orbi is not working correctly? Received an email from Netgear?)
The forum contains some very long posts regarding firmware updates. There are several differing opinions regarding the topic:
- Some users see no reason to update firmware unless there is a specific probem that a firmware update claims to address.
In other words, "if it ain't broke, don't fix it." (Similar to "let sleeping dogs lie.") - Some users (such as myself) neverinstall a firmware update until at least 3-4 weeks have gone by with other customers relating their experience with it. (Broke this... or Devices no long show up.. etc.)
- Some users believe, "Netgear told me an update was available, so I must install it."
- Some users like to "live on the edge"
There is also a concern that we see a lot of posts that start off, "I updated using the Orbi 'app' and now.... something awful."
Obviously thousands of Orbi customers must update firmware successfully using the app. Only those who have had problems turn up on the forum looking for a solution to the aftermath.
Gussom2c
Thank you for responding. Router firmware 2.3.5.30. Router 2.5.2.4. Issues are internet keeps dropping and can not update. Error is can not update
- CrimpOnFeb 11, 2021Guru - Experienced User
Gussom2c wrote:
Thank you for responding. Router firmware 2.3.5.30. Router 2.5.2.4. Issues are internet keeps dropping and can not update. Error is can not updateHow is the update being done (Orbi web interface or Orbi "app")?
- Gussom2cFeb 11, 2021Aspirant
The app
Gussom2c wrote:The app
OK. I do not want to appear obstructive, but there is no little evidence that updating the Orbi firmware will prove to be a solution to the performance problem. I am confused by the response: " Router firmware 2.3.5.30. Router 2.5.2.4." Perhaps that indicates that the router is now on firmware 2.3.5.0 and the desire is to install firmware 2.5.2.4?????
My recommendation is that the "app" is not your friend. I would use the Orbi web interface (http://orbilogin.net), go to the Advanced Tab, Administration, Firmware Update and follow the instructions to update firmware.
