Gussom2c
Feb 11, 2021Aspirant
Rbk53s-100nas
Hi need help orbi will not update P
Gussom2c
Thank you for responding. Router firmware 2.3.5.30. Router 2.5.2.4. Issues are internet keeps dropping and can not update. Error is can not update
CrimpOn
Feb 11, 2021Guru - Experienced User
How is the update being done (Orbi web interface or Orbi "app")?
- Gussom2cFeb 11, 2021Aspirant
The app
- CrimpOnFeb 11, 2021Guru - Experienced User
Gussom2c wrote:The app
OK. I do not want to appear obstructive, but there is no little evidence that updating the Orbi firmware will prove to be a solution to the performance problem. I am confused by the response: " Router firmware 2.3.5.30. Router 2.5.2.4." Perhaps that indicates that the router is now on firmware 2.3.5.0 and the desire is to install firmware 2.5.2.4?????
My recommendation is that the "app" is not your friend. I would use the Orbi web interface (http://orbilogin.net), go to the Advanced Tab, Administration, Firmware Update and follow the instructions to update firmware.
