samiam1234's avatar
samiam1234
RBK53S no internet connection
Hello,   I recently bought an Orbi RBK53 to use with my Cox (ugh) internet at home. I turned the panoramic modem/router into bridge mode (Technicolor CGM4140COM) using the login page at 192.168.0.1...
  • FURRYe38's avatar
    Feb 06, 2020
    Factory reset the RBR and use a wired PC or laptop connected to the RBR and walk thru the setup wizard with a web browser. I would also power OFF the isp modem for 30 seconds while the RBR is reset. Then log into Orbilogin.com or 192.168.1.1 with a web browser and begin the setup wizard.
