samiam1234
Feb 06, 2020Aspirant
RBK53S no internet connection
Hello, I recently bought an Orbi RBK53 to use with my Cox (ugh) internet at home. I turned the panoramic modem/router into bridge mode (Technicolor CGM4140COM) using the login page at 192.168.0.1...
- Feb 06, 2020
Factory reset the RBR and use a wired PC or laptop connected to the RBR and walk thru the setup wizard with a web browser. I would also power OFF the isp modem for 30 seconds while the RBR is reset. Then log into Orbilogin.com or 192.168.1.1 with a web browser and begin the setup wizard.
Feb 06, 2020Guru - Experienced User
samiam1234
I tried the reset and using my laptop with the same error. I swapped ethernet cables as well.
The setup client then asked me to try an alternate MAC address....so I tried the one on the modem/router combo from Cox and that seemed to do the trick.
Thanks for the help!
- FURRYe38Feb 06, 2020Guru - Experienced User
Modem Combo Units:
This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktopEnjoy. :smileywink:
- samiam1234Feb 06, 2020AspirantYes, I did place the cox gateway in Bridge mode from the start of setup.
Thanks!- FURRYe38Feb 06, 2020Guru - Experienced User
Awesome. Enjoy. :smileywink:
