MrTwonk
Nov 25, 2021Aspirant
RBK53s reset password on second hand Orbi
Hi, I've bought a Orbi 53s off ebay. I have tried to connect to the router by using the Orbi app and the QR code. When I tried to login to the router I use the sellers user name which he supplied, it...
CrimpOn
Nov 25, 2021Guru - Experienced User
Yes, a Factory Reset will erase all user information from the router. Reset them all and then configure them.
I personally highly recommend connecting a computer to the router with an ethernet cable and setting it up with the web interface (http://orbilogin.net)
MrTwonk
Many thanks
Dave
Dave
