wrleeii
Jan 20, 2020Aspirant
RBK53s Router drops modem connection
After 6 mo,the RBR50 router (part of the RBK53s package) has suddenly started dropping its connection several times a day. I either have to push its Sync button or when that doesn't work, power cycle...
Jan 20, 2020Guru - Experienced User
The most current FW version is v2.5.1.8. Stable and working for me.
Is the Orbi system operating in Router or AP mode?
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
wrleeii wrote:After 6 mo,the RBR50 router (part of the RBK53s package) has suddenly started dropping its connection several times a day. I either have to push its Sync button or when that doesn't work, power cycle it to get a connection again. Many times it will drop and it will resync itself after a few minutes without my pushing the sync button. I have not updated the firmware recently (v2.3.5.30), so I do not know what has triggered this behavior. The modem it's connected to is fine; I have not needed to power cycle it.
Frustrating! Should I look at replacing it?
