GolfarenBjarne
Jan 12, 2021Follower
RBK752 - RBK50
I have an Orbi RFBK 50, two units.Will now buy Orbi RBK752.two units.Can I use the satellite in RBK50 as part of the mesh system with RBK752, or will it affect the speed.
Jan 12, 2021Guru - Experienced User
Please visit post about this over in the Orbi AX forum:
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
You can only wire connect RBS50s to the Orbi AX system. There not wirelessly compatible.
Good Luck.
GolfarenBjarne wrote:I have an Orbi RFBK 50, two units.Will now buy Orbi RBK752.two units.Can I use the satellite in RBK50 as part of the mesh system with RBK752, or will it affect the speed.
