stlgasman's avatar
Jan 01, 2022
RBK752 Stable firmware
I have a RBK 752 which consists of a rbr750 router with a corresponding satellite. The system worked like a rockstar until some firmware update made it practically useless. It requires multiple reboots to connect to the Internet daily. Updating to the latest firmware 4.6.5.14 and resetting the router helped a little but still have constant issues. Are there any beta firmware that might help or would downgrading to an earlier version be helpful. If so, what is the best version to downgrade to? How do you downgrade the firmware?
1 Reply
