akhilstyle
Jan 21, 2022Tutor
RBK753 iOS Devices intermittent disconnect
Hi, I have a weird intermittent issue where various iPhones intermittently disconnect from my wifi for 5-7 mins. The wifi icon keeps spinning and there is no internet on the device. It automatical...
Jan 21, 2022Guru - Experienced User
What firmware is on the router?
And the firmware on the satellites?
What gateway is it connected to?
Is it only iphone/mac's with issue? Or does windows/android devices have problems as well?
- akhilstyleJan 21, 2022TutorHi,
Thanks for your reply. It only seems to be iPhones. I have 2 with the same issue. iPad seems ok.
Router 4.6.5.14
Satellite 4.6.5.14 as well
I just upgraded them to this firmware. I had the issue even on previous firmware’s.
It happens about once every 2 days or so.
Thanks
Akhil- plemansJan 21, 2022Guru - Experienced User
have you tried disabling the private wifi or random mac feature on the iphones?
- akhilstyleJan 21, 2022TutorI will try this. Thanks
