CDELL801's avatar
CDELL801
RBK753S in AP Mode
Just installed my Firewalla Purple, set my Orbi  RBK753S in AP mode and it looks like all of the wireless  connections are just going to the main  RBR750 and none of the   satellites have any  wirele...
  • CDELL801's avatar
    CDELL801
    Nov 02, 2021
    CrimpOn wrote:
    Changing from router mode to access point (AP) mode causes the entire Orbi system to reboot.  This might be a case of lots of frantic devices saying, "Where did my WiFi go?...... Oh, THERE it is." and connecting to the router because it is the first unit to begin broadcasting the WiFi SSID.
    It might be interesting to power cycle some of those devices that 'should' be connecting to a satellite and see where they connect.
    I have tried that,  but I have not rebooted all of the orbi's since I setup the Firewalla Purple.  Maybe I will reboot them and then try the devices again, but should they show up under the satellites connected devices?
