TheGrumpyGent
Dec 13, 2021Tutor
RBK850 - Access Control and Guest Network Blocking
Hello! Is there a way to use Access Control with the default set to "Block" but allow devices to join the Guest Network? I want to prevent new devices from joining the primary Home network (hence t...
- Dec 13, 2021
Netgear has set up a community forum specifically for the Orbi AX (WiFi 6) products. Most of the people who watch that forum are more likely to have experience with Orbi AX and know how to work it better than those of us who follow this "general Orbi" forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
Thank you
TheGrumpyGent
Dec 13, 2021Tutor
My apologies, that's twice I've done this now. I'll post there, thank you!
Dec 13, 2021Guru - Experienced User
