Happychap
Nov 23, 2020Aspirant
RBK852 with RBS50
So I just upgraded my Orbi network with the RBK852 model. I already was using the outdoor satellite RBS50 with my older orbi. Spent hours trying to sync the outdoor with the new system to no avail. I ...
Happychap
Nov 24, 2020Aspirant
Its RBS50Y. I am able to get the outdoor into extender mode in that i can go through the steps but when it comes to the step to connect to a wifi network it doesnt connect and the light turns pink.
Nov 24, 2020Guru - Experienced User
Are you trying to connect the RBSY near the RBR or in the same room as the RBR or at the remote location? Try near the RBR first.
