Alextkexichi
Jul 11, 2021Aspirant
RBK853 - unable to assign IP addresses
Hello and thanks in advance for your help - let me know if there's somewhere else more appropriate to ask this question please. When I attempt to assign IP addresses to devices on my network (Adv...
- Jul 14, 2021
To close the look for anyone looking, factory reset solved the issue. Was not as painful as I thought it would be either.
CrimpOn
Jul 11, 2021Guru - Experienced User
Yes, Netgear has a community forum set up specifically for the AX product line:
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
There is a chance that someone who has your product will notice a post in that forum.
Just in general, that 404 error is not supposed to happen.
Assigning IP addresses is also a bit goofy because Netgear's DHCP process seems to give devices the IP address they try to renew before it looks in the reservation table. When a device gets "stuck" on an IP address that I do not want it to have, my workaround has been:
- Turn the device off.
- Get out an old smartphone and configure it with that IP (static IP assignment).
- It will get on the network.
- Then, power on the troublesome device. It will ask, "can I have my IP again?". Orbi will do an ARP and decide, "Nope. there's already a device on the network with that IP. Oh, LOOK, here in this nice table it says you should have THIS IP address. Here."
Can you give that process a try?
- AlextkexichiJul 13, 2021Aspirant
Hey CrimpOn and thanks for the response. I've copied/reposted this question in the forum you referenced along with some more details.
FYI, I stated I was receiving a 404 error, but it's actually a 400 bad request error.
RBK853 - unable to assign IP addresses - NETGEAR Communities
- AlextkexichiJul 14, 2021Aspirant
- FURRYe38Jul 14, 2021Guru - Experienced User
Enjoy.
