Calvin1
Aug 02, 2021Aspirant
Rbk853 setup
I have my home setup using an Orbi rbk50 if I want to change to Orbi rbk853 how can I set it up so all of my current devices connected to the rbk50 will automatically connect to the rbk853?
Calvin1
Thx for the info.
Should I remove the rbk50 cable to the modem while setting up the RBK853 but leave the rbk50 powered on until the RBK853 is set up?
Aug 02, 2021Guru - Experienced User
You can move the ISP cable to the RBR850 while setting it up. Once it's setup and up and running, should be able to just turn OFF the RBR50.
https://community.netgear.com/t5/Orbi-AX/RBK853-setup/m-p/2123336/highlight/false#M17744
