GeoffWe's avatar
GeoffWe
RBR / RBD40 - Jan 2025 Firmware Update Notification - Is it a hack?
Today my Orbi UI for my old, (i thought) unsupported RBR40 and RBS40 notified me of a firmware update.    I think you're update system might have been compromised!     Screenshot below.      ...
  • FURRYe38's avatar
    Its it would be legit. Only auto updates come from NG. NG told me the 40 and 50 series are getting this update. Usually takes NG longer to post the file up on there download site. NG pushes to the AU services first in small batches. Then will post the files.
