HelpPlease21
Apr 18, 2021Follower
RBR / RBS 20 dropping internet
Hi All - I’ve been having issues with Orbi dropping my internet intermittently every 15-30min. We recently increased our internet speed to 400mb and the problem seems to have gotten worse. We have the...
Holylifton
Jul 12, 2021Aspirant
I've beed struggling with the same issue since about the same time.
| Model Name | Device Name | Status | ||
| Router | RBR20 | V2.6.2.104 | No new firmware version available. | |
| Satellite | RBS20 | V2.6.2.104 | No new firmware version available. | |
- FURRYe38Jul 12, 2021Guru - Experienced User
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too?- HolyliftonJul 12, 2021Aspirant
ISP modem HW is
Model:TG3482GVendor:ARRIS Group, Inc.SW version is
eMTA & DOCSIS Software Version:7.2.4.0.152- FURRYe38Jul 12, 2021Guru - Experienced User
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
https://kb.netgear.com/26765/Disabled-Features-on-the-Router-when-set-to-AP-Mode
Holylifton wrote:ISP modem HW is
