HelpPlease21
Apr 18, 2021Follower
RBR / RBS 20 dropping internet
Hi All - I’ve been having issues with Orbi dropping my internet intermittently every 15-30min. We recently increased our internet speed to 400mb and the problem seems to have gotten worse. We have the...
Jul 12, 2021Guru - Experienced User
Holylifton
Jul 12, 2021Aspirant
ISP modem HW is
Model:TG3482G
Vendor:ARRIS Group, Inc.
SW version is
eMTA & DOCSIS Software Version:7.2.4.0.152
- FURRYe38Jul 12, 2021Guru - Experienced User
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
https://kb.netgear.com/26765/Disabled-Features-on-the-Router-when-set-to-AP-Mode
Holylifton wrote:ISP modem HW is
Model:TG3482GVendor:ARRIS Group, Inc.SW version is
eMTA & DOCSIS Software Version:7.2.4.0.152- HolyliftonJul 12, 2021Aspirant
The ISP modem is already in bridge mode. Worked witht eh ISP this past weekend and they see no signal drops from the modem so it appears the issue is with the Orbo router. They're sending me a boposter. I set the modem to gateway and turn off the orbi router and satelites. We'll see if the problem goes away.
Important to note that I had a dependable internet connection for years with this configuration. It just started happening the past few months. I did update the FWon tyhe orbi mesh to V2.6.2.104 and I'm wondering if that has anything to do with it.
