Pether
Dec 26, 2019Follower
Rbr 10 satellite not working properly
Just bought the Orbi rbr10 mesh set. While the main router and one satellite is working perfect, the second satellite is having issues. It connects to the rest of the setup just fine, but it seems lik...
Dec 26, 2019Guru - Experienced User
What happens if you swap places with the other RBS?
Pether wrote:
Just bought the Orbi rbr10 mesh set. While the main router and one satellite is working perfect, the second satellite is having issues. It connects to the rest of the setup just fine, but it seems like no devices (phones, tablets, pc etc) is able to connect to it. I have changed its position to be closer to the main router, without any effect. Anyone have a possible solution?
