KitPrin
Jun 28, 2020Follower
RBR 10 wont change channel on 5GHz
Hello! After seeing a couple buffering issues on the 5GHz channel I checked for interference and found quite a bit. When I went to change the channel I found that the 2.4 GHz could be changed but the ...
Jun 28, 2020Guru - Experienced User
Are you using a mobile browser to do this or a PC and web browser?
Has a factory reset been performed and setup from scratch with the RBR using a PC and web browser? Try IE11 or FireFox?
