venksiva63
Oct 04, 2020Aspirant
RBR 10
RBR 10 - 4 satellites I have gigabit internet from my provider (Century Link), and the Orbi app tells me that the speed is 700+ Mbps download and 850+ Mbps upload, which some research has told me is...
venksiva63
Are you testing over 2.4ghz or 5ghz? 5 GHZ
The orbi devices do bandsteering and can move devices between 2.4ghz and 5ghz.
2.4ghz is much much slower than 5ghz. I dont know what this means
Also, just an fyi, the RBR10's aren't going to hit gigabit speeds over wireless. The primary router can do it over a hardwired connection but wouldn't hit it over wireless. Its fine i dont need Gigabit i just need a decent speed like atleat 200-300 speeds.
Oct 04, 2020Guru - Experienced User
Your sure your device is connected to 5gh?
What device are you testing on?
A device with only a 1x1 antenna isn't going to have the same speed as a 2x2 device.
