kmcumber
Jul 20, 2020Follower
RBR 20-Need an additional satellite
I have the RBR 20 with 1 satellite. I would like to add an additional satellite. Its there an option to buy one? Will one of the other models work? Suggestions?
Jul 20, 2020Guru - Experienced User
If you can find them available at retailers, yes you can of course.
RBS20, RBW30, RBS50, RBS50Y, EX7500 and EX7700 should all work with RBR20.
- brettcohenJul 20, 2020AspirantMine is a AC3000 kit. It has the RBK50 unit. Is that the same as the AC2200 network? Will the same satellite units work?
- FURRYe38Jul 20, 2020Guru - Experienced User
No, not quite the same however similar. Wireless backhaul is 866 on the 20 series, the 50 series is 1733.
Yes.
