kmcumber
Jul 20, 2020Follower
RBR 20-Need an additional satellite
I have the RBR 20 with 1 satellite. I would like to add an additional satellite. Its there an option to buy one? Will one of the other models work? Suggestions?
Jul 20, 2020Guru - Experienced User
If you can find them available at retailers, yes you can of course.
RBS20, RBW30, RBS50, RBS50Y, EX7500 and EX7700 should all work with RBR20.
brettcohen
Jul 20, 2020Aspirant
Mine is a AC3000 kit. It has the RBK50 unit. Is that the same as the AC2200 network? Will the same satellite units work?
- FURRYe38Jul 20, 2020Guru - Experienced User
No, not quite the same however similar. Wireless backhaul is 866 on the 20 series, the 50 series is 1733.
Yes.
