Notdonor
Jul 21, 2020Aspirant
RBR 20 obtaining IP address errors
Hello, recently my network has had some frustrating issues connecting various things to my router. I can connect all smart phones and tablets fine. I can not connect my desktop with a wireless adapter...
Jul 21, 2020Guru - Experienced User
Try enabling Beamforming and MIMO(MIMO may or may not be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
- NotdonorJul 21, 2020Aspirant
Current Firmware is V2.5.1.16
Modem is Arris TM1602
Distance between satellites is 20-30 feet
I have made all the changes you suggested and its still the same.
Router was factory reset and resetup this afternoon.
- FURRYe38Jul 22, 2020Guru - Experienced User
What is the mfr and model # of the wifi adapter on the PC?
Be sure the adapters wifi driver is updated.
I have heard of some PS4s not connecting wirelessly to Orbi. If the other PS connects and the other doesn't, I would presume there maybe a difference on the Pro version. Something to ask Sony about. I would wire connect the Pro version to see if it connects to the back of the RBR.
- NotdonorJul 22, 2020Aspirant
Wireless adaper is a Linksys WUSB6300. It has been updated to the most current driver.
