TH65
Jan 20, 2020Follower
RBR 20 Orbi Router- How to connect a Brother HL2170W printer to the network using WiFi ?
So I bought the Orbi RBR20 model and setting up the network was a breeze. However when I try to add my Brother HL2170 W wireless printer I run into issues. When I configure the printer itand print a ...
- Jul 06, 2020Solved!!! If you click the reset pin button on the back on a Brother HL-2170w and press the black sync button. The key is press the button for a click of a second or less. Any longer and it messes it up
CrimpOn
Jan 20, 2020Guru - Experienced User
It will help if you describe how the test page is being printed. i.e. from a computer? tablet? smart phone?
Does the Orbi web interface or "app" indicate that the printer is connected?
