TH65
Jan 20, 2020Follower
RBR 20 Orbi Router- How to connect a Brother HL2170W printer to the network using WiFi ?
So I bought the Orbi RBR20 model and setting up the network was a breeze. However when I try to add my Brother HL2170 W wireless printer I run into issues. When I configure the printer itand print a ...
- Jul 06, 2020Solved!!! If you click the reset pin button on the back on a Brother HL-2170w and press the black sync button. The key is press the button for a click of a second or less. Any longer and it messes it up
Mikey94025
Jan 20, 2020Hero
If you're able to successfully print a test page but cannot print other documents from other apps, then it sounds like your issue is with your operating system and not Orbi. Are you using a Windows PC or laptop? Windows can report that printers "are offline".
In Windows 10 try this:
- Win-R and type in "control panel" to bring up the Control Panel
- Under Hardware and Sound, click on "View devices and printers"
- Scroll down to Printers and left-cick (select) your printer
- Click on "See what's printing" in the top bar to bring up this printer's specific queue window
- In the Printer menu, select "Set as Default Printer" so the checkmark appears next to it
- Make sure that the checkmark is NOT next to "Use Printer Offline". If it is, select the item to toggle the state of the checkmark so it is OFF.
