Revdacjr
Feb 06, 2020Aspirant
RBR 40 - turn off Scheduled Internet
I need help turning off a scheduled internet blackout. I set a schedule to turn off the internet to test it. The router updated the firmware, and now I can’t turn the schedule off. There is no o...
Feb 06, 2020Guru - Experienced User
What browser are you using? Does this happen with IE11, Firefox or Opera?
Factory reset the RBR and setup from scratch. This time don't enable any internet schedule.
I would make a back up configuration to file. Then if you need to set the schedule again and need to revert back, apply the saved backup configuration from file which doesnt' include the internet block schedule.
