Pmpic
Mar 22, 2023Aspirant
Rbr 40 and rbs50 questiom
I have an rbr40 with 2 satellites ..I just purchased an rbs50 to add on...would it be better to swap the main hub from the 40 to the 50 and use all 40s as satellites ...or just add the 50 as a 3rd sat...
CrimpOn
Mar 22, 2023Guru - Experienced User
Please double check the model number of the add on.
If it is really RBS50, then it can only be added as a satellite.
If it is actually an RBR50, then it can take the place of the RBR40 router (which cannot be turned into a satellite), so you end up with what you started with: one router and two satellites.
- PmpicMar 22, 2023AspirantThank you
I appreciate it
