harpandiesel
May 23, 2020Aspirant
RBR 40 Issues with green ring
I have had the Orbi RBR system for 2 1/2 years and it just fell off my network. I could get nowhere with it and had a buddy mess it. After multiped it.le attempts of loading firmware, it finally acce...
harpandiesel
Thank you for the reply.
I can not connect to it with a wire. I have pressed the reset button and held for a minute. I cannot connect with a wire whether or not it is connected to my modem.
May 26, 2020Guru - Experienced User
You'll need to contact NG support and ask for help and information regarding this. RMA if thats an option.
Good Luck.
harpandiesel wrote:Thank you for the reply.
