yhn280
Aug 01, 2020Tutor
RBR 40 needs reset every morning
My Orbi has been working great for the past 2 years until 4 days ago. With no changes to our router or gateway, my WiFi drops every morning when I wake up. Both my default and guest network is showin...
Aug 01, 2020Guru - Experienced User
Try enabling Beamforming and MIMO(MIMO may or may not be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M97026
v16 working:
https://community.netgear.com/t5/Orbi/Orbi-SOAP-and-Excel/m-p/1901857/highlight/false#M90178
https://community.netgear.com/t5/Orbi/RBR20-RBS20-2-5-1-16-firmware-observations/m-p/1897766/highlight/true#M89405
Has a factory reset and setup from scratch been performed since last update?
