DGz73
Feb 16, 2020Aspirant
RBR 40
Can a RBR 40 work with a RBR50 router?
DGz73
Thank you for the quick reply.
Think I did not pose my question right, I have a RBR 40 Orbi with two satellites. The RBR 40 router broke so just checking if I can use the RBR 40 satellites with a AC3000 router.
Actually appreciate the rant helpful.
CrimpOn
Feb 16, 2020Guru - Experienced User
Are you ever in luck. YES. All Orbi satellites can be used with any Orbi router.
