sbatten21
Mar 03, 2020Follower
RBR 40
My Orbi RB40 is not transmitting wifi signal and I have confirmed internet connection / signal to modem is fine.
Mar 03, 2020Guru - Experienced User
Do you see the default SSID name if you do a factory reset on the RBR? Press the reset button in back for 15 seconds then release.
