CaraBethP
Aug 22, 2021Tutor
RBR 50 - 3 years perfect now my desktop is VERY slow online
Firmware is v2.7.3.22 on Orbi. Orbi network name: Desktop is a Dell with up to date OS. RBR 50 and satellite have connected without fail for 3 years. I have Spectrum internet service regularly a...
- Aug 31, 2021
I see the adapter is only connecting at 200Mpbs.
Specs say it should connnect:
Peak Speed: 433 Mbps
Standards: 802.11ac Wave 2, 802.11a/b/g, 802.11n
Wi-Fi Spectral Bands: 2.4 GHz, 5 GHz
Channel Utilization: 20/40/80 MHz
MIMO Configuration: 1x1 (1-stream) <Not great for connection rates and speeds.
CaraBethP
Aug 31, 2021Tutor
screenshot attached
Aug 31, 2021Guru - Experienced User
Can you attach that by using the Choose File button on your next post? A forum moderator has to approve inline pictures.
- CaraBethPAug 31, 2021Tutor
screenshot attached
- FURRYe38Aug 31, 2021Guru - Experienced User
- CaraBethPSep 01, 2021Tutor
Thanks so much for your help. I have been online chatting with Dell. They are sending a technician and a new wireless card.
I wouldn't have been able to convince them to do that if you hadn't told me what was up!
Many Thanks!
- FURRYe38Sep 01, 2021Guru - Experienced User
Good to hear. :smileywink:
